Links to Stepcraft forum and within forum go "bad"
If I write in some other forum and put a link to Stepcraft forum then after a while the link doesn`t work (error 404). Same thing happens to linking within forum. What is up with that? I can open links in to other forums that were posted five years ago etc. Doesn`t leave a good impression abot Stepcraft to people interested in finding out more.
Proxxon IBS/E
Mach3
![Markus Wedel Markus Wedel](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/markus.wedel_25756.png)
Thank you for the information. We will look after this asap.
Markus
Have a look at the cnc-wiki.de. There are thousands of links directly into the forum and they work since years.
Do you have some weird browser plugin that changes the links? Would probably be helpful to post an example of such a link here in text-form without function.
Here is an example. I can`t open those two links in the topic anymore (posts 10133 and 10164). One more example: post 16838 Last in text form should be: https://www.stepcraft-systems.com/en/servie-and-support/stepcraft-forum-uk/assembly-and-maintenance/1168-s600-build-experience
Note: inserted space before https so that it wouldn`t be active. With space removed: https://www.stepcraft-systems.com/en/servie-and-support/stepcraft-forum-uk/assembly-and-maintenance/1168-s600-build-experience
Proxxon IBS/E
Mach3
you habe to editiert the URL am Lotte Bit the IT Works
https://www.stepcraft-systems.com/en/forum/assembly-and-maintenance/1168-s600-build-experience
http://cnc-wiki.de/
![Dirk Thörner Dirk Thörner](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/Dirk%20Thoerner_25738.png)
The URL is not correct. It should be "service-and-support" instaed of "servie-and-support". The "c" is missing. That is the issue
Thank you for the replies. I hope I didn`t cause that problem somehow. I swear the links were working at the beginning.
Proxxon IBS/E
Mach3
- 7,511 Themen
- 8 Online
