Add Drag Knife / Cutter to Forum "Applications"
I got the drag knife cutter with my stepcraft 2 600 in the US kickstarter. I have no milling experience whatsoever, but so far using the milling operations has been easily learned. I tried to use the drag knife on 0.2 mm vinyl(with removable backing). I have failed miserably to get this working without destroying the vinyl.
I cant seem find any good instructions /examples in this forum, or a good place to ask the following questions.
1. What is the best way to fix the vinyl sheet to the machine and what sacrificial material should i use below the vinyl.
2. Do i set the cutter depth to 0.2 mm or more?
3. How much pressure or excess z distance should be applied to the cutter?
Any other good practices or feed speeds would be very insightful.
Thanks
![Hal Eccles Hal Eccles](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/hale2160_28759.jpg)
I also got the drag knife with my Steppi and so far I have only cut paper and thin card for a test.
After a quick chat with Rory from Stoney CNC this is how I set it up:
MDF as a sacrificial board
Taped down the paper/vinyl
Set the cut depth to the thickness of the material (digital verniers)
Then brought the Z down until the white plastic bearing just touched the paper
The cut the material
I use Vcarve Pro software and within that there is drag knife gadjet that makes setting up pretty easy. When I cut the card I had to re-run the cut a couple of times for a clean cut.
Hope this helps.
SC840, HF500, UCNNC, Vcarve Pro, Turbo Cad
- 19 Online
