Whats the best spindle?
Hello all, I am currently trying to spec up a D series 840 and am wondering what is the best spindle option to go for with the easiest operation
I would like to have the option to have a tool changer and a speed controller and the options are all a little confusing on the site
So it would be one of these
https://shop.stepcraft-systems.com/AMB-Milling-Motor-1050-FME-P-Portal-230V-with-external-speed-control-for-d-series
or
https://shop.stepcraft-systems.com/AMB-Milling-Motor-1050-FME-1-DI-with-automatic-tool-changer
What are the differences between the different names? its not very clear (FME-P or FME-1-DI)
I will be milling a wide range of materials up to aluminium so really want to get the correct spindle
any help would be great including links to previous posts on this subject
![Gerhard Widmann Gerhard Widmann](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/cygnus_29434.jpg)
Hello Viken
In my opinion the Kress 1050 FME milling motor is the best spindle!
I have been using it for about 4 years without any problems.
The milling motor is a bit noisy, especially at high speeds, but it has the best price-performance ratio.
By the way, the speed can be controlled.
Another advantage is the excellent concentricity of the collet chuck and the milling cutter.
Greetings cygnus
Stepcraft 420/2 mit WinPcNc-USB, Kress 1050, QCAD, Estlcam
Bedenke, dass auch ein Tritt in den Hintern einen Schritt vorwärts bedeuten kann.
Thanks cygnus, that will be the one we go for then
Hello Viken,
I try to explain,
"What are the differences between the different names? its not very clear (FME-P or FME-1-DI)"
Both are Kress or Kress related spindels of the FME serie and both have 1050 Watt power.
The "P" stands for the collet size in this case a the collet standard of ER-16, you can use any collet of this series to mach your milling bit max dia is 10 mm.
the 1D has a tool change module attached for the ATC and has a collet standard of ER-11, so any collet of this series can be used max dia is 7 mm (this is shaft diameter of course).
Both machines are very good and stable.
Just remember that for the ATC you need an AirCompressor and a pressure of 4-6 bar to operate the ATC
good luck
- 7 Online
