Fixed air blast
Clearing the chips is a serious problem when milling Aluminum, Plexiglas or other easy melting material.
So I made a poor man's air blast that cools your bit and blast the chips away from your work piece and all of that for less than € 15,00 (if you have some material).
Material used;
Aluminum plate 1 mm
Aluminum rod dia 10 mm
Plastic tube dia 2,4 mm (left over from pushrod housing for RC planes)
Nuts and washers for 6 mm thread
An Airbrush hose with 1/8 BSP threat (cost € 3,00)
An 2 or more way airbrush coupling (cost € 10,00)
First I a made a base plate that fits under the dust collector, in this case a proxxon ISB/E motor.
I use a 1 mm Aluminum plate and bent the hole 90 deg so it fits on de clamp screw.
Second take a piece of 10 mm rod approx 5 cm and clamp in lathe, first I made the 1/8 threat over a length of 2,5 cm. Than mill the thickness to 6,1 mm and make the 6 mm threat so that you keep 1 cm 1/8 threat left. Now drill in lathe a hole of 2,4 mm over 2,8 mm. At last cut off the remaining material.
Push the pushrod tube in the hole and with a little heat bent it in shape.
Assemble and connect hose and distributer to compressor, Done!!
enjoy
- 9 Online
