New Laser module fo...
New Laser module for the Stepcraft
13 Beiträge
13 Benutzer
12.8 K Ansichten
Javier Valencia Rodriguez
(@jvalencia)
Just saw it on this video (go to 0:39), and more things to see: a water bed and a big cabinet for the machine (looks expensive).
https://www.youtube.com/watch?v=0u_FBiQrO3c
Another video:
https://www.youtube.com/watch?v=wmFV5jeOsHI
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Veröffentlicht : 01/05/2016 6:50 pm
(@mathieu-hebbrecht)
When will it release??
Veröffentlicht : 25/08/2016 9:48 am
Roy Rathner
(@derroy)
Reputable Member
Unfortunately this Video is quite "old" already.
It has been taken during the fair Intermodellbau which took place in April already.
MfG
Roy
Veröffentlicht : 25/08/2016 3:21 pm
(@svanmieghem)
I am also waiting for the stepcraft laser module. Any news?
Veröffentlicht : 26/09/2016 9:13 am
Markku Lehtola
(@sloworks)
It's on shop now, but there's nothing about software requirements, is it working with WinPC-NC full/starter, UCCNC? Any idea?
br
Markku
www.stepcraft.fi (reseller in Finland)
www.sloworks.fi
SOLIDWORKS, WinPC-NC Full, EstlCAM, SC1/600 + HF500W, laser
BCN3D Sigma
Veröffentlicht : 09/11/2016 7:55 pm
bluskies
(@bluskies)
Hi!
I ordered one a few days ago. The web shop says shipping from early December. Those videos and other preview said there would be two models (2 W & 6 W) but there was only one in the shop indicating 1000 mW (1W). I am curious to whether I'll be able to upgrade if there is a higher output model later :-p
There is not much info on software or anything, but I hope it will come with some control software. Seems there is a control box. On newer photos a small grey box with air extraction fan laying on the table in the background, but in the videos the control box was larger and orange like the other control boxes from Stepcraft.
This was really like ordering myself a Christmas present, I have no idea what will be in the box, only that it will (hopefully) arrive before the holiday, including everything needed to use it :unsure:
Best regards
Audun
Veröffentlicht : 16/11/2016 6:01 pm
Sven Weinmann
(@sickone4)
Honorable Member
THE CAT. Definitely the cat will be in the box.
Unfortunatly there is no software. But I can tell you rumors (me...!) will tell, there will be a first release of LaserCAm. A software that edits the ESTLCam DIN files to a DIN file that can be used for your laser and WINPcNc.
Maybe this will help you out 🙂
but the cat will be in there anyways...
Sven
Veröffentlicht : 16/11/2016 7:08 pm
(@cncmiller)
Reputable Member
If you look at "Inkscape" a vector drawing progam witch has an "Laser tool plug-in".
With that you can create the necessary code for the Stepcraft and the best, Its for free!
https://jtechphotonics.com/?page_id=2012
maybe this will help
Veröffentlicht : 16/11/2016 8:52 pm
 Owen
(@owen-s)
Does anyone here have one of these up and running?
If so what do you like using it for?
If so what are your thoughts?
Cheers,
Owen S.
Veröffentlicht : 06/03/2017 4:46 pm
(@pattarom)
I did not found laser module in the shop, it was removed?
Veröffentlicht : 22/03/2017 10:55 am
Hartmut
(@docbrown)
Honorable Member
As I remember there was a problem with the life-time of the laser-diode. So we've to wait for a new supplier for the laser-module.
Hartmut
ESTLCAM & QCAD
DK5LH/G11
Veröffentlicht : 22/03/2017 12:44 pm
Michael Lux
(@mikerd03)
Reputable Member
Last time I visited Stepcraft here in Germany I saw some assembled lasers on the desk, so I would guess it won't take too long. 😉
Veröffentlicht : 22/03/2017 5:13 pm
(@nd595)
Semiconductor lasers weakest point is that they need a powerful and very efficient cooling systems. If laser diode temperature goes above +50 degrees Celsium at any time, the diode will not last for long. I am using a 10W blue laser diode with custom driver and a complicated cooling (includes a Peltier element and a big aluminium heatsink to dissipate the heat) - but IMHO, this is only for engraving. If you want to laser cut things, you will be much better off with CO2 40W laser engraver/cutter; just beware of a cheap chinese ones - they do work, but the required setting up and necessary modifications are not for everyone.
Veröffentlicht : 22/04/2017 11:44 am
