Problems with the z-axis
Hi there,
A few days ago I assembled a Stepcraft 300. After tuning the mechanics I went and look at the software. Followed the manual and decided to print an own made object:
- Saved the 3D file as .STL;
- Opened the STL with StepCraft Repetier;
- Slic3d it;
- Saved the .gcode;
- Opened the .gcode with WinPC USB;
- Started the program:
The first layer is printed, just as expected. When the stepcraft wants to print the second layer, it tries to print it beneath the first layer.
- I stopped the program
- Went into WinPC USB's settings;
- Found a check box that reverses the Z-Axis;
- Tinkered with a few other settings to enhance the machine;
- Started the program again:
The stepcraft prints the object perfectly. Right untill the end. When its done with it's final layer, the machine turns "god mode" and destroys the object completely with its Z-Axis. The machines probably wants to lift the Z-Axis untill it's above the material before it's send to his park position. That's logical if you're milling, but I'm not milling I'm printing. In fact everytime I want to stop a program and press "stop" the machine first homes to the Z-axis.
My question is, what have I done wrong? Or aren't I wrong and simply missed a checkbox? Or are the problems within StepCraft (I haven't done any tinkering with that program)?
Please help,
Roelofs
First issue sounds like a mirrored Z axis setting in WinPC... not sure as never used it to run Gcode.
The second issue sounds like the final instruction is to correct... which could also be winPC profile?
At the end of the program the final instruction should move the machine away from the part...
anyone with WinPC exepreince who can help here?
Hello all.
I've got same problem, I've had to install last version of Slic3r software, and the more important, configure Repetier-Host as a Router CNC instead of a Cartesian 3D printer (default), things go better now, though I have some problems fixing the coordinates of the part, no matter where I fix it, when the gcode is generated, it always start near X88, Y33. An immature software, I hope next versions will fix these problems.
![Markus Wedel Markus Wedel](http://stepcraft-systems.com/wp-content/uploads/wpforo/avatars/markus.wedel_25756.png)
Hi guys,
have you imported the parameter file for WinPC-NC? (see First Steps brochure, page 9,, sentence in red)
Markus
Adidas Tobacco Vintage
Attempt incorporating cut ice-cubes to the juices to make it a cool treat during the summer! It's like drinking a fruit smoothie although in fact knowing what substances will be in it and in which they originated from (and the way clean they were once they moved in the juice extractor!) What a yummy strategy to chill out.
The complete most critical element of your article is definitely the headline. It is the headline that will seize the interest of the viewers and enable them to to decide to read through further more through your report. Decide on among the more significant factors with your post and will include it in your name.
Skechers Scarpe Amazon
Will not make an effort to achieve a number of shades with your wardrobe. All of this will work is mix up your eye area and give everybody who examines you a frustration. As an alternative, make an effort to decide on a wardrobe with only 2 or 3 colors highest to ensure men and women can concentrate on your clothing collection rather than quite a few colors.
If somebody in your house is an symptoms of asthma individual, usually do not light up at home, car, or anywhere all around them. People who do wish to smoke will need to go outside, considerably out of the home and also the person who has asthma attack. Large cigarette smokers may possibly induce an asthma attack invasion by merely having the fragrance of light up on his or her garments.
Uomo Skechers Gorun Ultra
When evaluating a cosmetic surgeon, price must not be a deciding element in the operating specialist that you choose. Usually do not simply choose the operating specialist having the lowest cost. Prices are no sign of the caliber of the surgeon, and the outcomes you get. It can be an indicator of their experience. Regardless of whether, they will be usually the one carrying out the surgery.
Learning and coping with character is among the ideal way to spend your hard-earned getaway time. Load and get ready with all that you should create your camping outdoors venture a hit, and make certain to help keep every one of the recommendations out of this article in your mind making it go far more easily.You May Live An Acne Outbreak Using These Suggestions
Смотрите порно фото и секс фото крупным планом
http://ero-iaponki.porngalleries.top/?page-nikki
Бесплатные секс и порно фото галереи
Галерея порно фото ради взрослых
http://igrivaia-aziatochka.sexblog.top/?blog-adrienne
Анальный секс, фото галереи анала, секс фото
http://top-siski.toptorrents.top/?blog-juliana
Секс фото галереи для взрослых
http://siski.molodie.purplesphere.in/?page-ansley
Порно фото - уставиться онлайн безвозмездно
cfbiivy
http://www.studiolafratta.it/092-stan-smith-adidas-opinioni.htm
http://www.birraceria.it/070-asics-scarpe-bimbo.htm
http://www.tiratardipub.it/negozi-new-balance-ravenna-221.html
http://www.menteprofonda.it/scarpe-prada-luna-rossa-2017-476.htm
http://www.longchampaliexpress.fr/longchamps-2016
Scarpe Golden Goose Shop Online
Jimmy Choo Collezione Sposa 2017
Nike Free Rn Flyknit Vs Motion
Scarpe Asics Negozi
Adidas Scarpe 2014
Nike Air Force Retro
If you do not know if your snoring loudly originates from apnea or just easy heavy snoring, use a rest journal. With this log, you need to record the time you spend in bed, the number of instances that you simply awaken each night, and exactly how exhausted you sense once you arise every morning.
The much stronger the body, the better you'll truly feel about you. It's amazing how focusing on body building can change the entire prospect on existence! I hope that what you've read in the following paragraphs allows you to begin working out in such a way which makes you sense fantastic everyday.Adding Beautiful Jewelry In Your Wardrobe
duweqzb
http://www.sebastienmagro.fr/chaussure-tubular-nova-primeknit-477.html
http://www.izi-form.fr/acheter-mont-blanc-moins-cher-128.htm
http://www.english-food.fr/nike-air-max-1-ultra-essentials-femme-850.php
http://www.soc16.fr/christian-dior-chaussures-femme-501.asp
http://www.essaisgratuits.fr/golden-goose-deluxe-brand-paris-190.php
Nike Stefan Janoski Achat
Louboutin Mec
Nike Cortez Premium Baseball Pack
New Balance Wl574 Bleu Et Orange
Ray Ban Femme Clubmaster
mjtasos
http://www.sebastienmagro.fr/neo-adidas-amazon-036.html
http://www.izi-form.fr/beats-pro-321.htm
http://www.lyceerenedescartes77.fr/401-huarache-customize.html
http://www.gamick.fr/chaussure-new-balance-2017-451.html
http://www.lyoncentre.fr/509-nike-sb-janoski.html
Adidas Yeezy Boost 350 Femme Rose
Adidas Superstar 80s
Nike Schweiz Billig
Chaussure Christian Louboutin Femme
Chaussure De Sport New Balance Pas Cher
- 7,509 Themen
- 9 Online
