I've created a project in Fusion 360 that involves milling both sides of a piece of wood. Up until now, I've only milled the top side of projects.
In fusion 360 it seemed that I could easily design a tool path for the underside by changing the tool orientation z-axis to be able to approach it. The problem arises with the stepcraft post-processor not liking the produced data.
I imagine this is a common requirement, so there must be a simple way to work around this.
Is anyone able to help with this, or point to where it's already been discussed?
I'm fairly new to Fusion 360, but have had success with simple projects and self-learning so far.
Thanks!
Ben
resulting G-code excerpt with error codes:
Information: Configuration: STEPCRAFT UCCNC
Information: Vendor: UCCNC
Information: Posting intermediate data to [snip]
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Friday, August 18, 2017 3:09:44 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41465
Configuration path: [snip]\Autodesk\Fusion 360 CAM\Posts\stepcraft uccnc.cps
Include paths: [snip]
Configuration modification date: Saturday, August 12, 2017 11:31:52 PM
Output path: [snip]
Checksum of intermediate NC data: [snip]
Checksum of configuration: [snip]
Vendor url:
www.cncdrive.com/
Legal: Copyright (C) 2012-2017 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3253
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
