- Dank erhalten: 0
MagIO2 schrieb: Wrong type of Aluminium. The specs I found say that it is bad to mill/drill.
Firstly, this is completely incorrect. 6061 (T6) should machine no problem because it is a harder grade. Look at the Brinell hardness factor.MagIO2 schrieb: Wrong type of Aluminium. The specs I found say that it is bad to mill/drill.
No thanks. Machinability is related to the material hardness and not specific to professional CNC mills. Rory recommended 0.1 mm depth of cut per pass on the Stepcraft system. I am comfortable with that from what I have witnessed. Additionally, I do not require to remove more material per pass for my small aluminium sheet parts although I think the Stepcraft would cope. If I needed to mill more aggressively I would have specified and purchased a different machine and spindle.MagIO2 schrieb: I think those kind of statements you find in the specs refer to a professional CNC mill. Reading your parameter proposal seconds this .. 0.1 mm depth per pass ...
You should try the other alloy! There you have 0.5-1mm per pass. This is where acceptable starts for me ;o)
It stopped when the cycle finished, as normal. The video is not complete; there is a pocket cut missing because the camera turned itself off.jonalm schrieb: what happened at the end it just stopped?
