file Frage Max. tool diameter to mill oak (roughing pass) ?
05 Feb 2017 18:12 #43816 von norbert_00
Hello,
I intend to buy a Stepcraft 420 with a Kress 800 spindle to mill small decorative oak panels.
For the roughing pass, what is the maximum straight cutter diameter I can expect to use ?
Can I foresee a 7mm slotting cutter (shank 6mm, www.sorotec.de/shop/Cutting-Tools/WOOD/slotting-cutter/Slotting-Cutter---7-0mm-S6.html ) for oak rough milling ?
Are the following cutting parameters adequate ?
pass depth : 1,5mm
stepover : 30 % (2,1mm for a 7mm dia. Tool)
spindle speed : 15000 rpm
feed rate : 25mm/sec
plunge rate : 10mm/sec
Do you think these parameters values are acceptable or not ?
Thank you very much to share your experience on this point.
Best regards,
Norbert
05 Feb 2017 21:49 - 05 Feb 2017 21:50 #43827 von Doug
Hi Norbert.
I successfully removed 2.00 mm per pass at 2,000 mm/min (33 mm/s) on oak with a 4.00 mm diameter solid carbide four flute flat end mill at a spindle speed of 20,000 rpm recently so I would say that your parameters are acceptable, perhaps a little conservative.
Do some testing at higher speeds and greater depths to see what your system can easily accommodate.
Regards.
Doug
Hobby use: guitar building (luthiery), dsgb.net
Letzte Änderung: 05 Feb 2017 21:50 von Doug.
06 Feb 2017 18:39 #43861 von norbert_00
Thank you very much for your answer, Doug ; I will try with those values.
Best regards,
Norbert
