Spindle Startup Fail
After resolving a profile issue with V1 settings on a V2 machine X,Y, and Z motors, I have had good repeatable results. I already have a second paying job on the mill!
But I did end up ruining a piece of wood because the spindle failed to start up completely.
Process-
Clicked start job as I had done on several other pieces.
The spindle got about 10 turns into its windup then stopped.
It is almost as if the spindle is calling for too many amps on startup and shuts down.
This has happened twice, the second time i was able to hit the e-stop before crashing into the piece.
Anybody have similar experiences?
Are there V2 settings I need to change for the spindle too?
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
1/8" 60 Deg 4 Flute V Bit
1/8" 4-Flute Square Nose End Mill
1/8" 2 Flute Ball Nose End Mill
1/16" 2 Flute Ball Nose End Mill
UCCNC and VCarve Pro
Total Newbie!
Yes - had exatly that same problem on my HF350. See my post in "Accessories" on 14th Nov.
I've had no further reply back from Rory yet, so I assume Stepcraft have ignored his enquiry for the time being.
In the short term I have worked around the problem by inserting a 5 second delay after the M03 command - this gives plenty of time to reach the J.C. button if the startup fails. I don't think there is anything in the profile that can affect this behavior as far as I can tell.
Once the stop is removed and the system reset, I set the programme on the next instruction after the delay, start the spindle from the screen button and, if all is well, then restart the cycle.
UC100 + UCCNC
I have also had similar problem on my HF500. This has happened so often that my checklist now includes steps that start cycle, verify that the spindle starts while keeping mouse over reset button, and when I hear it to start then I let go of mouse.
Also when this happens once on the job, it will happen every single time until I reset the stepcraft itself. Restarting UCCNC or powercycling the HF500 spindle controller does not fix the issue. I can still start the HF by pressing the button on the spindle controller, so I usually just then manually start spindle and finish the part that way.
Hmm... looking at my logs this happened 3 times earlier for the same weekend, but haven't happened since, so it might be that the issue disapperared. Anyways I did raise the delay after the spindle start to 5 seconds just to give me more time.
Stepcraft 2 840 Kickstarter make anything package
HF500, 3D print, Drag Knife, etc
UCCNC + UC100, V-Carve
If you have to cycle the power on the Stepcraft before things return to normal, then your problem seems to be subtly different to the one that Remotruker and I have experienced. Maybe your pwm frequency is different or the percentages for minimum and maximum speeds are different.
On my system anyway, the fault seems to appear quite at random - and does not seem to be affected by the eventual final speed demand. From this I suspect that the problem is with the initial acceleration phase of the startup.
I can promote the fault by continually starting and stopping the spindle via the on-screen button - it seems to fail once every 5 - 10 start attempts.
UC100 + UCCNC
Thanks for the responses all... Just so to cover all the bases, here are my spindle settings
I see some settings under acceleration steps- I know with VFDs if you accelerate too quickly it can shut down a drive and you have to ramp up the speed up slower. Similar?
Seems Stepcraft has some work to do here. I know it is a hobby grade machine, but for $2+k, I'm disappointed in the quality control. Missing parts, mis-shipped parts, wrong config CD, Spindle issues...
I can't say I would highly recommend this to a friend.
My machine doesn't need to be power cycled, just re-start the file and it has always worked on the second attempt.
Stepcraft 2 420
500 Watt Spindle
3D Printing System
3d Probe
T-Slot Table
Tooling:
Total Newbie!
For what it's worth here is my HF350 configuration.
The settings were chosen to get the best correlation between UCCNC speed demand and measured no load speed.
On my spindle the minimum speed is approximately 6000rpm, which is the minimum speed setting in the config. The pwm frequency affected linearity, too high and there was very poor speed correlation, too low and the speed hunts about a nominal setting. Rock and a hard place scenario!!
UC100 + UCCNC
- 7,336 Themen
- 3 Online
