file Frage Procedure for cutting two toolpaths
12 Nov 2015 00:22 #26873 von jonalm
Procedure for cutting two toolpaths wurde erstellt von jonalm
Im using uccnc, how would you go about using two toolpaths with two different size endmills on the the same job.
12 Nov 2015 00:51 #26874 von Christian Knüll
Christian Knüll antwortete auf Procedure for cutting two toolpaths
if you use Estlcam you just create 2 different tools in the tool list and then create the toolpaths with the according tools:
Your machine will automatically stop once a different tool is required and after changing you just resume the program.
12 Nov 2015 00:56 #26875 von FaFiNoS
FaFiNoS antwortete auf Procedure for cutting two toolpaths
Select vectors only for 1.5mm endmill, create toolpath, save gcode. After that select vectors for 2.0mm, create toolpath and save code. Go ahead with miling 1.5mm and when finished change tool to 2.0mm. Now you need to find zero position for Z axis (tool length sensor is handy) and go with miling 2.0mm.
S600 v2, HF500, FME 1050, Industrial quality small HF spindle and many many other things.
12 Nov 2015 01:17 #26876 von jonalm
jonalm antwortete auf Procedure for cutting two toolpaths
Uccnc will only except one toolpath at any one time right? so after i load the toolpath for the 2mm cut, does it matter where the x/y postion is?
12 Nov 2015 01:27 #26877 von FaFiNoS
You can load any gcode and X and Y positions remain the same (Z as well). Do not zero it! You need new X and Y positions only if you remove miling part from machine and put it back again. After loading new toolpath you only need new Z position because you changed the tool.
FaFiNoS
Folgende Benutzer bedankten sich: jonalm
12 Nov 2015 01:30 #26878 von Christian Knüll
UCCNC can handle files with more than one tool.
X/Y is not affected by tool changes - but Z will be because of different tool length.
12 Nov 2015 12:30 #26890 von jonalm
Thanks, ill try that.
13 Nov 2015 18:50 #26954 von Rory
Yup -spot on - save two separate toolpaths with the same XY zero datum in the CAM side. Don't change UCCNC XY zero and change tool - zero Z and run program!
16 Nov 2015 21:11 #27110 von Kivinen
Kivinen antwortete auf Procedure for cutting two toolpaths
Make also sure that in your UCCNC profile you have changed the Configuration / General Settings so that it will stop the spindle and wait for Cycle start on tool change code M6 if you generate G-code that uses multiple tools in same file.
I think the default is "Ignore tool change code (M6)", so it will happily just go past all M6 codes, and will not stop and allow you to change tool.
And to generate multiple toolpaths using different tools to same file, you need to use some postprocessor that supports tool changes (I would assume "Mach2/3 ATC Arcs (mm)" might work).
Stepcraft 2 840 Kickstarter make anything package
HF500, 3D print, Drag Knife, etc
UCCNC + UC100, V-Carve
Folgende Benutzer bedankten sich: MarcelMe
03 Apr 2017 17:11 #46089 von idecorwalls
idecorwalls antwortete auf Procedure for cutting two toolpaths
Hello,
I just hit "Go to Zero" in UCCNC after changing the tool.
It worked great.
