Oblong Circles
I am trying to cut out some small washers/flanges out of acetal, dia. 14mm. However, the circles are coming out a little mishapen. At a guess, the Y axis stopped for second and the X continued so there's a little straight section but I have cut out a second set, changing material position and zero positions etc. and get the same issue. Hoping someone else has encountered this before and has a solution or possible solutions 🙂 thanks.
Hi Evan,
This could well be due to your backlash settings being incorrect - are you using UCCNC and UC100 to drive your machine?
The correct setting are quite difficult to achieve because you are looking for errors of the order of a few 10's of microns - I was fortunate enough to have a small microscope with a calibrated graticule to view some test patterns.
Peter
UC100 + UCCNC
Evan check this too: https://www.stepcraft-systems.com/en/servie-and-support/stepcraft-forum-uk/software2/2307-difference-between-constant-mode-and-exact-mode
If you want full precission, go with Exact Mode.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Thanks jvalencia, I changed to Exact Stop mode on UCCNC and has made an improvement on the 'roundness' of the circle but looks like it might indeed be the backlash as the errors would be at the points of axis reversal. A bit more tinkering to do, thanks for all your help.
- 7,333 Themen
- 12 Online
