Help needed: PCB milling (Eagle, WinPC-NC Starter)
Hello everyone,
I've been trying all day to convert a simple test PCB in Eagle to something useable for WinPC-NC starter. I've tried exporting as DXF, a plugin to export as SVG and PCB-GCODE. I've also tried using EstlCAM.
Instead of Eagle, I've also tried using DipTrace for creating the PCB, which works a little better than the other options.
In short, I tried everything to convert a board in Eagle to useable file for WinPC-NC starter.
Is there anyone out there who can help me with this problem?
Unfortunatly, as a student, the purchase of the Stepcraft drained my bankaccount so I have no more money for expensive software, so I'm looking for freeware options.
Thanks!
By now I have finally managed to get PCB-GCODE to work properly, but estlcam doesnt handle it very well, and WinPC-NC doesnt handle it at all :
The first attachement is how the G-code looks in a viewer/g-code convertor (to DXF).
The second attachement is how the DXF looks in WinPC-NC starter (I have got the same result with different programs and conversions and whatnot, so I doubt the g-code convertor is buddy)
I solved the issue!
Here is my method to make a PCB using Eagle and WinPC-NC Starter:
1. Use the PCB-GCODE plugin for Eagle to generate the gcode file
2. Load the gcode into G-Code-ripper and convert it to DXF
3. Open the DXF in QCAD, save as DXF (R12, this is important)
4. Open it in your CAM processor is you think thats necessairy or load it in WinPC-NC
5. ???
6. Profit 🙂
edit: only issue remaining is that the size is way too big, but that shouldn't be to hard to figure out
Just an idea. Use Inkscape to vectorize the png image.
And then import the svg with your CAD software.
[edit]
mmm I'm reading that Eagle has a DXF export function.
link to groups.google.com post
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
I've tried that, but the Eagle DXF doesn't even look okay in Inkscape
Can you try opening it with QCad? It's free.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
I'll try it when I get home, but as I mentioned yesterday, I have a fix for the issue (although fairly complicated). But it would be great if we could figure out a more elegant solution!
Sorry for taking a while, but, I tried opening the DXF by Eagle in QCad and it looks fairly okay, but the ground plane isn't there en the traces are just lines, which isn't very great as well
Hi Sibert,
This may not be practical for you at the moment, but if and when you have the chance to upgrade your software do give serious consideration to UCCNC with a UC100 motion controller.
After a lot of uncertainty at the beginning I decided to go that route when I ordered my SC420/2. I have no regrets at all about that decision. UCCNC is straightforward and intuitive to use, will directly handle the G code format that is used almost universally for CNC machines. Vectric progammes such as Cut2d produce G-code that works correctly without any further intervention.
I also wanted the ability to mill pcb prototypes from Eagle board layouts. The G code produced by the PCB-GCODE ulp runs faultlessly on the 420, and allows full control of the machine via the setup pages. I plotted my first trial effort and posted the results in this forum last week.
I hasten to add that I have no connection with any of the items I have mentioned other than being a very satisfied user.
Peter
UC100 + UCCNC
Hello,
Another vote for UCCNC and the UC100 USB Controller - our SC600 has been running without a hitch for well over 6 months now.
Rory Stoney is the man with the answers and very good support.
R
Okay, so I've been considering the other software, but my bank account really doesn't allow it.
I have been thinking though. I have a raspberryPi (and therefor Linux) at my disposal. Is it an option to use LinuxCNC with my raspberry pi (which also would mean my PC doesnt have to be close to the machine)?
I don't think that LinuxCNC is available as a Raspian package or as a Pi distibution. Furtheron I doubt that the Pi could generate timings accurate enough to drive the steppers.
Nevertheless I am also dreaming of a combo of a Pi and a mikrocontroller which can drive a CNC standalone. I already have the hardware but have a lack of time to do the coding.
PS: On CNC end of your problem, WinPC starter is enough for PCB milling. You only need to find the right tools to generate the files it can cope with.
- 7,336 Themen
- 4 Online
