question-circle Frage PWM modulation WinPC-NC USB
02 Sep 2020 19:30 #59467 von CNCMiller
PWM modulation WinPC-NC USB wurde erstellt von CNCMiller
Hello there,
Anyone with experience how to use the PWM mode on a laser with the WinPC-NC USB software?
I have a S 420 v.1 and use WinPC_NC v. 3.4 for the Laser I use a NEJE 20W (5,5W optic power) with TTL / PWM mode.
for generation of g-code I use the vectric Laser post processor "WinPC-NC ATC Arcs Laser No Z mm (*.nc)"
How can I use the PWM mode in combination with WinPC?
Witch pin do I use on the D15 connector (I assume pin 7 for PWM and pin 3 for TTL mode) in combination with the GND pin?
What setting should I make in the WinPC programm to adjust the power of the laser (in M or G code )?
or should I make changes in the post-processor G-code?
Hope for some guidance in this.
04 Jun 2021 09:17 #61178 von CNCMiller
CNCMiller antwortete auf PWM modulation WinPC-NC USB
To all,
I have found the right way to use the laser and PWM modulation in WinPC-NC.
You can find the procedure to set this up on:
www.lewetz.de/en/faq/how-to-with-winpc-nc
topic:
Laser configuration and laser test functions
and my post about How to... on this forum
