VFD setup with M700 + UCCNC
Custom Applications
1
Beiträge
1
Benutzer
0
Likes
342
Ansichten
I'm trying to setting up a HF spindle + AT1 inverter on my M700 machine.
Either I get PWM + 5V START SIGNAL direclty from the SUB-D (Case1)
Or I get a 0-10V analog speed signal from the PWM converter cable ( https://shop.stepcraft-systems.com/PWM-Converter-Set) but no START SIGNAL
In both case I'm stuck :
- My VFD doesn't read PWD
- I need a kind of relay to connect VFD ground to START pin. The 5V signal doesn't do the trick
So at the moment I'm using the spindle manually.
Is there any advice to read ?
Veröffentlicht : 13/03/2024 3:42 pm
Forum Information
- 7,336 Themen
- 6 Online
Unser neuestes Mitglied: robert23
Letzter Beitrag: Komplexe SVG-Datei fräsen - Probleme, die Strukturen auszuwählen
Forum Icons:
Themen-Icons:
Unbeantwortet
Beantwortet
Aktiv
Heiß
Oben angepinnt
Nicht genehmigt
Gelöst
Privat
Geschlossen
