HF-500 Controller (Power Supply)
Eric Royer was kind enough to replace the faulty power supply for my controller. Not too bright on my part - thought I was careful to draw the colors/wiring connections, but they sure don't agree, even though the new PS is identical. Would someone please write/diagram the connections/wire colors from the wires on the controller to the terminals on the power supply? I tried the Kress router for awhile, and it's ok, but want to return to the air-cooled spindle as it has much better programmatic (UCCNC or Mach4) control. Thanks everyone.
Additional info/clarification:
Unfortunately, I must have mis-labeled the wires/connections and I can find NO documentation on the wiring for this PS. What I diagrammed for the 9 screw terminals on the PS is (from left to right) : 1-Not Used, 2-Not Used, 3-Red, 4-Not used, 5-Large Black, 6&7-Fuse with 7 a Yellow/Green Combo, 8-White, 9-Small Black. Inside the controller box w/ circuit board, I failed to draw which side of the "posts", inside or outside, the Yellow/Orange/Brown combo plugs into (also Yellow at the top or bottom?). Lastly, the second Yellow/Green combo has a standard crimp connector, but unclear what it would plug onto (there are 4 wire "posts", but would be very loose, and which of the 4? Perhaps a photo of all would help, if this is not clear enough.
- 7,341 Themen
