About the anti-backlash official nut
Have anyone tried it yet?
I mean this one: https://shop.stepcraft-systems.com/lead-screw-nut-rg10x3mm_1
I'm having backlash on X axis.
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
Hi, I have fitted them all OK and even with no real adjustment they improve the movement as they are slightly longer, but replace the original ones. Even just screwing on the lead screw the slackness is greatly reduced, but to really fit properly the lead screws need to be taken off and each one set up (adjust screw tension) then put back, also as I had the machine dismantled fully removed the grease and now use the white lithium.
To fully replace you need 4 nuts.
SC600/2, Kress 1050, UCCNC with UC100, Cut2D Pro, TurboCAD and Fusion 360
Thank you Alan, I'll give it a try 😉
[edit]
Damn, shipping costs are high for a single nut. I'll have to invent something :unsure:
Stepcraft 2 840
Kress 800 FME
UCCNC + UC100
V-Carve + QCad
- 5 Online
