file Frage Z axis stop turn.
  • mikath
  • mikaths Avatar Autor
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
25 Mai 2017 18:44 #47605 von mikath
Z axis stop turn. wurde erstellt von mikath
The Z axis stoped turning suddenly.
My first thought was that any screw has loosened on the axel, but no.
I´m using UCCNC and when I "quick jog" shift+jog it turn for some reason.
Could it depend on any of the three cables that have gone off?
/Mika+
Stepcraft M.1000 + HIWIN Ball Screw + Semi-Closed Loop System + MM-1000 DI + Automatic Tool Changer + 2 Rows Tool Magazine Pneumatic Lifting + Engraving Laser DL445 + 4th Axis + Aluminum T-slot table + 3D Touch Probe + UCR201 + UCCNC + VCarve Pro + Cut3D + CorelDraw 2018 + Autodesk Inventor
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
25 Mai 2017 21:50 #47613 von mikath
mikath antwortete auf Z axis stop turn.
This is a video of what happening.
/Mika+
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
28 Mai 2017 07:07 #47640 von mikath
The motor has no power, and I can stop it with my fingers without any problems.
No one has any idea what it might be wrong ???
/Mika+
28 Mai 2017 10:34 - 28 Mai 2017 10:40 #47645 von peterg1000
peterg1000 antwortete auf Z axis stop turn.
Hi Mikath,
It looks very much as though only one of the two stepper coils is being driven. Three possibilities for this situstion :-
1) Fractured wire or loose connection in the wiring loom. (Most likely)
2) Open circuit winding inside stepper motor. (Not very likely - low resistance and thick wire)
3) Faulty stepper driver chip. (Unlikely for only one channel to fail - usually all or nothing)
Given that it is likely to be a fractured wire, I guess you will have hours of fun unwiring the gantry. :evil:
Peter
UC100 + UCCNC
Letzte Änderung: 28 Mai 2017 10:40 von peterg1000. Grund: spelling correction
Folgende Benutzer bedankten sich: mikath
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
28 Mai 2017 14:24 #47650 von mikath
Thanks for your reply.
Initially, I'll try to change the X or Y axis to Z to see that there is no error on the PCB.
My fear is to rewire the gantry... :(
/Mika+
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
28 Mai 2017 14:33 #47651 von mikath
One other thing I noticed is that the motor has a very high frequency of noise, the other motorss are completely silent.
/Mika+
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
28 Mai 2017 21:16 #47667 von mikath
Now I have changed the X motor to Z on the PCB and it work like a charm.
I think it´s a fractured wire.
/Mika+
28 Mai 2017 21:42 #47669 von peterg1000
Hi Mika,
Glad you've probably found the problem.
Don't envy you having to unwire the gantry to find the culprit. Good luck!
Peter.
UC100 + UCCNC
  • mikath
  • Offline
  • Forum Nutzer
  • Forum Nutzer
  • SV&LV
31 Mai 2017 15:29 #47757 von mikath
I cut the cables and replaced with new ones and now all the axis work.
It does not look so nice at the moment, but I can fix it when I have new parts.
/Mika+
