file Frage Se-2300 set up
05 Nov 2019 13:02 #57612 von AlanUK
Se-2300 set up wurde erstellt von AlanUK
Hi, Am trying to set up the SE-2300 with my 600/2 using UCCNC, I need help in setting up the spindle page in UCCNC, not sure which sections are used.
Thanks in advance
SC600/2, Kress 1050, UCCNC with UC100, Cut2D Pro, TurboCAD and Fusion 360
06 Nov 2019 08:52 #57615 von Rahul
Rahul antwortete auf Se-2300 set up
AlanUK schrieb: Hi, Am trying to set up the SE-2300 with my 600/2 using UCCNC, I need help in setting up the spindle page in UCCNC, not sure which sections are used.
Thanks in advance
You need to set one of the three pin (LPT PIN1, 14 or 16) to switch on the spindle in UCCNC.
Then set the jumper to the appropiate position at the SE-2300.
I use WInPC-NC so I don't know where to make these settings in UCCNC.
Ragards
Folgende Benutzer bedankten sich: AlanUK
17 Dez 2019 17:32 #57825 von Taylor
Taylor antwortete auf Se-2300 set up
I have just bought this switch unit and am lost as to how to connect the d sub cable. I have one that comes from the back of the machine, goes into and out of the board on the enclosure and then goes into the back of the HF control unit. So as the 2300 only has a single d sub in how does work?
