file Frage Remote Power Controller not working
23 Aug 2019 01:49 #57240 von cmendoza
Remote Power Controller not working wurde erstellt von cmendoza
Hi All,
I just finished setting up my 840/2 and I'm trying to get the Power Controller for the to work with the MM-1000 but the spindle will not turn on. The MM-1000 works when I plug it directly to the wall, and the 840 seems to be doing what it's supposed to do, but the spindle does not turn on when I press the "clockwise" button in UCCNC. All the connections are correct. Is there anything any way to test or debug the Power Controller? Is there a way to turn on the spindle other than the "clockwise" button in UCCNC? Any additional debugging steps I should know about?
Thanks!
c.
28 Aug 2019 20:46 - 28 Aug 2019 21:05 #57260 von Reiner St.
Reiner St. antwortete auf Remote Power Controller not working
Hello cmendoza,
The MM1000 milling machine does not have a power controller, but can only be switched on and off by the software.
You have to adjust the power yourself on the milling machine (see setting wheel X 1-6) from the following manual : www.stepcraft-systems.com/images/SC-Service/Anleitungen-EN/Operating-Manual-MM-1000_v3.pdf
You can switch the MM 1000 on and off via the software, but you need the Switch Unit SE 2300.
This can be connected to the milling machine and via the software a relay inside the switch unit switches the milling machine on or off.
Greetings Reiner
3D Druck: Anycubic Photon S, i3 Mega S,Chiron,TENLOG TL-3D PRO, Zonestar...
Letzte Änderung: 28 Aug 2019 21:05 von Reiner St..
