Stepcraft SC100 Pinouts
I'm looking to add some extras to my setup, incluing a coolant solenoid and control of FRENIC Mini inverter for the ELTE Spindle I'm using.
I'm guessing the way to do this with the SC100 is to wire things up to the D Connector? If that is the case, does anyone know the pin outs? I'm guessing they are different from the pins that can be configured within UCCNC?
Many thanks in advance
Rob
I don't know what a SC100 is but does this help you?
https://www.stepcraft-systems.com/images/Service/EN-Operating-Instructions-SC2-v2.pdf
Page 17
if your using a UC100 and wire direct to the output then nothing will be isolated.
better solution is to use a UC300 - connect one port to the SC just like the UC100 and then use the other ports to connect to your hardware via breakout board with isolation.
- 7,336 Themen
