How to setup tool length sensor in UCCNC?
Hello,
can anybody help me in setting up my UCCNC to work with the Stepcraft tool length sensor?
I have the sensor connected and when I manually activate it I can see output "10" change value in the software so I know it works. But how to configure the software and then use it with the sensor, I have no idea and can't find anything about it, not online nor in the UCCNC manual.
Can anybody help me?
Thanks in advance,
Regards,
Sander
I second this question.
if you have figured this out I'd appreciate your help.
thanks
James
Sander has the first position on the solution for this.
We have a working probe profile that allows automated Z height setting.
when time permits we will formalise the documentation and post.
IF you want the profile drop us a mail.
Hi Rory ,
Can you help me with the tool length sensor I have the UC300 and the new software UCCNC 1.1012 . everything else is going well . please give me an info
Thank you
SC 300,
ESTLcam 8.
Designer CAD,
Proxxon IBS/E
Mach3 mit UC 300 (5x LPT)
UCNC mit UC300
Eigenbau Handrad
probe pin should be pin 10 (but check this before you test - so you should see pin 10 trigger when you press the tool length sensor).
You then nee the M31 Macro (hopefully attached) and replace with the one you already have in your UCCNC marco profile folder.
Hi Rory
thanks for the quick response , I also tested the same.
Unfortunately without success , the z axis moves according to under the anschlag.ich have the UC 300 and the new SoftwareUCCNC 1.1012 it is perhaps because .
I am crazy werden.Alles goes not switch box the handwheel with keyboard ( all homemade ) , only the tool length sensor .
HELP !!!!
Best Regards
SC 300,
ESTLcam 8.
Designer CAD,
Proxxon IBS/E
UCNC mit UC300
Eigenbau Handrad
Hi Rory,
everything is ok, error lay with me the file in the wrong folder copied.
many thanks for the help
best regards Wolfgang
SC 300,
ESTLcam 8.
Designer CAD,
Proxxon IBS/E
UCNC mit UC300
Eigenbau Handrad
- 7,336 Themen
